I've had my top end off for porting and before I put it on I want to oil/greese the crank bearings but I don't know if you use a certain type of oil or certain type of greese, can any one let me know what I need to use?
Thanks.
The crank bearings are lubricated with the 2 stroke oil you mix in your fuel. There is no need to add any additional oil, but you can if you want to. Just don't get too carried away, otherwise you'll smoke up the place real bad when you start the engine up!
what ever pre mix oil you are using poor alittle on each and all over if you want it will smoke and probably fould out the plug but it willl start and run ok just change them after initila start and break in
Ok, well I put the top end on last night, I just put a couple drops of my 2 cycle on it, I was only asking because in the service manual it said to put "engin oil" on it and I wasn't sure what they meant by that.
Thanks for your replys.
