Hi guys, im new to the board, i have a 97 banshee with small motor mods, it has a good crank, .010 bore, T5 exhaust, reeds, and no head or carb work, i was lookin to get my head ported or a new head, which should i do? i do a lot of trail riding and i look for a little draging on the weekends, any suggestions would help.
ya cant get your head ported but you can get it milled<machining a fraction of an inch off the bottom to raise compression> but if you have the cash consider a coolhead or a noss head.changeble domes<combustion chambers>for compression and better cooling for under 300$
alright, thanks alot, is noss the best brand head for my application?, is it a real noticable power gain?, and what size domes do i need to still run on pump gas? Im in atl area so im guessing im somewhere in between sea level and 1000 feet.
i have a PD head and like it, but ive never run a noss, so i dont know. as for the dome size check THIS out. scroll down a little, and take a peek at the chart. ;)
Welcome, depending how much you what to spend,and what type of fuel you want to burn will help you decide.If your going to run pump gas I would mill the head.Mine cost $25 at the local auto parts. about .030 max. keep your cylinder pressure below 165 psi. if you want more power and run race fuel, get the after market head for more compression and better cooling.
Edited by FIRST BANSHEE
