Decided to change the needle clip position. So took it all apart and went to put it back together and slightly bent the needle :angry: I also droped my slide about 3 ft on to the ground. So I decided to straighten the needle the best I could. I put it back in the carb and the slide went down but not sure if it went all the way down. I then put the cap on half way and pressed the throttle a few times to see if it was having any problems. I didn't notice any. So I screwed the caps on all the way and checked the throttle again and I couldn't even press it in. It was stuck!!! :angry:
I then took the carb cap off and wasn't able to pull the slide out. So I took off the air fitlter and stuck a flat head in the intake and pushed up the slide enough so that I could take the throttle cable off the slide. I then removed the carb from the bike and took it in side. I stuck the screwdriver through the carb and pulled on it reall hard to get the slide to pop out.
I then took the needle off the slide, cleaned the carb out good and tryed to put the slide with out the needle back in the carb. ( yes the correct way) The slide falls freely until the top of the slide is 1/2" below the carb top and it gets stuck again. :( If you push hard on the slide it will go the whole way but that cant be right.
So what the hell is wrong? Is my slide bent? It looks fine to me. The carb dosen't have any scratchs that I can see to prevent the slide from falling down.
NEED HELP!!! :shrugani:
Another problem. They slid fine then I put them in the shee. I rode it around for about 5 minutes up and down the road. And now it is getting stuck again. banghead What the f*ck. I took the carb out again and I have to push hard to get the carb to slide up and down. :confused:
sanding won't hurt it, the black is just a tephlon to make it more slippery. when you dropped it, you must have egg-shaped it or made a burr on an edge...if you egg-shaped it, then I'd get a new slide.
