racer714 Posted October 15, 2004 Report Posted October 15, 2004 Hey experts out there, I was wondering how the air screws affect bottom to mid throttle? If it idles ok and revs ok, then wont rev hardly at all and bogs after it warms up, could it be due to my airscrews being out of adjustment? ANY INFO WOULD BE GREATLY APPRECIATED!!!! PEACE Quote
Banchetta Posted October 16, 2004 Report Posted October 16, 2004 Try adjusting them and go from there. From what it sounds like your pilots are too big, turning the air screws out will help a little but they only fine tune the pilots... Quote
racer714 Posted October 16, 2004 Author Report Posted October 16, 2004 Thanks Bachetta, ill try that, any other takes on this situation? Quote
Toomey Banshee Posted October 16, 2004 Report Posted October 16, 2004 did you disconnect your tors and parking brake yet? If not that may be the problem. If it revs ok and then suddenly doesnt and idles ok and suddenly doesnt I would bet thats where your problem is. Quote
SDD Posted October 16, 2004 Report Posted October 16, 2004 (edited) They way how I tune in the air screws is warm up the bike and let it idle. Now hit the trottle pretty fast (don't pin it but at least half throttle) and listen for any bog or delay before it revs up. If it bogs try to turn them half a turn out and see if it will rev up cleanly. If you can't get it to rev up cleanly no matter what air screw setting you try you should rejet your pilot jets and try again. The air screws will not effect the midrange like you describe. Your problem sounds more like a needle setting adjustment than anything. Edited October 16, 2004 by SDD Quote
