This depends on the brand of skid plate. The shock linkage interfers with all but the stock skid plate. The PRM skid plates and others that are designed to protect the shock linkage need to be significantly altered, such as removing the portion that is designed to protect the shock linkage. The rest of them just need a little clearancing on the front edge of the skid plate.
If I have my swingarm shortened then will an aftermarket skidplate still be able to bolt right on.
If the person the shortens it move the tabs it will work fine.
I guess I was only talking about the stock plate. You heard the answer from the man himself..... cutter matt ;) ...
ex cutter matt that is.
