williamjernigan Posted October 5, 2004 Report Posted October 5, 2004 I am planning to do all my mods at once. I have fmf sst's, k&n, 15 tooth front sprocket and -2 swingarm on the way. I know their are alot of different oppinions about carbs and the setup but with the mods I have mentioned do you think that I first of all should get bigger carbs, single carb kit, or no carbs at all. Quote
FIRST BANSHEE Posted October 5, 2004 Report Posted October 5, 2004 I have the trinity cv intake with a single carb.It's easy to tune and makes good power. Quote
Justintoxicated Posted October 5, 2004 Report Posted October 5, 2004 (edited) honestly, I woulde just keep the stock carbs untill you do some motor work. Maybe get the TORS Removal kit to making jettng easier, but event hat is not necessary, since FMF's charts should get you close to perfect on the first time depending on your mods elivation and temperatures....The stock carbs are perfect for a banshee with pipes, and air filter mod, otherwise I would only go up one size at the most. But since your getting SST's and not Fattys my guess is that you do not plan to port an polish anytime soon? Edited October 5, 2004 by Justintoxicated Quote
fixitrod Posted October 6, 2004 Report Posted October 6, 2004 (edited) You most likely will not benefit much from new carbs. But, if you ride in water or want them to be easier to jet don't spend the money on a tors removal kit. Just get some 28mm carbs. The tors kit is around $70. New carbs can be had for around $200 with a cable. You can still use your stock boot with keihn carbs that size. You'd get better suggestions if you let us know what type of riding you do. Edited October 6, 2004 by fixitrod Quote
decon Posted October 6, 2004 Report Posted October 6, 2004 from reading around on the forums i would have to say the cv setup from trinity. get a 35mm carb with it. Quote
