okay ive got 33pwks same pilots same mains same airscrew settings yadda yadda
anyway, she smokes like crazy on the left side the whole engine is rebuilt compression is the same plugs are the same. it runs great all the time but the left side is smokin somethin bad only at ide and up to the main up top she is great
but theres no bogging or farting at all it just smokes more
any ideas?
try changing the plugs then if it's still there, there maybe an issue in the carb, maybe the air screw on the one side needs some adjustment. I've seen where the air screw on one may be a little more in or out when compared to the other.
Since you have aftermarket carbs you can switch sides with them. Then you'll be able to tell if it's the carb or something in the engine. If the smoke follows the carbs, you know where to look without chasing your tail all day.
