I have recently purchased a 99 banshee. I noticed that when I pull clutch handle in, the and rev the gas it wants to creep forward very slightly.So I put a new clutch cable on it. The new cable helped alot but it still wants to creep up I have no adjustment left at the clutch lever.The clutch does not slip at all thru the gears.I thought maybe someone had changed the clutch and did not adjust the rod. Kind of a pain in the butt getting it into neutral with it wanting to creep.Any ideas?
make sure that the case mark and the clutch arm that goes into the upper case half its self are lined up if not the adjust the push rod adjusment which is located in the pressure plate until they line up or the clutch arm is just a lil past the case mark(closer to the sprocket) then readjust your handle until u have hardly any slack at all about 1/8" of slack will do just fine but i usually run mine a lil less. once u get all this done right u shouldnt have another problem. if u dont already have it done to your clutch cover while u have it pulled off i would reccomend drilling a hole in it under the insert so u dont have to remove the cover to adjust it next time and u shouldnt have a problem with a leak espically if your running a aftermarket insert which uses an oring
