jinx44 Posted September 8, 2004 Report Posted September 8, 2004 I am wanting the narrower width of the blaster axle for my banshee. I am running into a couple of problems. The stock blaster brake rotor hub just floats on the axle. Will this work with the hydraulic brakes of the banshee as long as you keep it oiled so it can slide? I don't see a problem with it. The rotor hub is also shorter on the blaster, and it is turned around the opposite way. I have a LSR hub that I think will work with modification. Other than a drag axle, do you have any other ideas? Quote
