I have vito's super stock forged pistons .100 over bore (66.42mm on left and 65.92 on right). I'm installing a cool head with 19cc domes. My question is will I have enough clearance? I had my stock head milled .040 and the pistons were hitting the head gasket. May have used wrong gasket? Maybe rod strecthed?
.040 shouldn't have been hitting the head gasket. I have a stroker and it had to go through the head gasket and I never had a problem. It was .040. I don't know what other head gasket would even be close to a banshee head gasket. You don't have a big bore motor do you?
bore is .100 over. The head gasket cut a groove into the top of the piston. It is a banshee head gasket. Do the head gaskets standard or are the matched to the over bore.
there are over bore head gaskets. i know on my kx 500 i would have to get one if i bore it. i would imagine that you need to on a banshee also being that the head gaskest are pretty close to the bore to keep a tight seal.
:unsure: my bike is stock so i can't help you there buddy sorry. but i would also like to know because i am lookin at all that stuff for my bike.
