They are 3 more curves for you to try out. How they respond is going to vary a bit with how your shee is set up. It doesn't cost any extra to try all 4 of them out, so might as well try them all.
Curve 1 advances the whole curve(except idle) several degrees. It should pull strongly at low RPM, and taper off up top.
Curve 2 is advanced slightly less than 1, it will give a little more power in the mid-upper RPM.
Curve 3 has a lot more advance at low-mid RPM that drops off up top, to give you decent upper RPM, with a strong mid range.
Brad
Dynatek
Edited by bradrs
