DGFUNNY70 Posted August 30, 2004 Report Posted August 30, 2004 THE INSTRUCTIONS THAT CAME WITH IT SEEM TO BE VERY VAGE STOCK IS OBVIOUS BUT WHAT IS CURVE ONE TWO AND TREE IN THAT ORDER. Quote
94BansheeRider Posted August 31, 2004 Report Posted August 31, 2004 Should be: low, mid, and high, in that order. Quote
bradrs Posted August 31, 2004 Report Posted August 31, 2004 (edited) They are 3 more curves for you to try out. How they respond is going to vary a bit with how your shee is set up. It doesn't cost any extra to try all 4 of them out, so might as well try them all. Curve 1 advances the whole curve(except idle) several degrees. It should pull strongly at low RPM, and taper off up top. Curve 2 is advanced slightly less than 1, it will give a little more power in the mid-upper RPM. Curve 3 has a lot more advance at low-mid RPM that drops off up top, to give you decent upper RPM, with a strong mid range. Brad Dynatek Edited August 31, 2004 by bradrs Quote
bradrs Posted September 1, 2004 Report Posted September 1, 2004 Many customers have reported they need to go up a couple on the main jet. Quote
