Noob Banshee Posted August 21, 2004 Report Posted August 21, 2004 Hello again, Well now i have a job now and im working on my engine. I got them resurfaced. Now all i need to get the engine put togetther is (pistons, wrist pins, rings,and clip ring that hold them in) I have a new set of gaskets already, becouse i just got the them resurface can i get the same size piston that i had before or do i have to go bigger? Does n e 1 know if wiseco just the items i listed above if so i can be done with the engine. any help, comments. suggestions, or any thing would help. Quote
MotulMonsta Posted August 21, 2004 Report Posted August 21, 2004 If you only honed the cylinders out, you can re-use your old ones. You should always have the pistons you want on hand whenever you do any machining to your cylinders. Make shure the proper clearences are kept and you should be fine. Quote
Noob Banshee Posted August 21, 2004 Author Report Posted August 21, 2004 i couldnt find out how big the ones i had where cuz they dont say on them Quote
roosthrower Posted August 21, 2004 Report Posted August 21, 2004 Time to bust out the micrometer. Quote
Noob Banshee Posted August 21, 2004 Author Report Posted August 21, 2004 ok i used a lil gas to see them they are 50 over so now i just get 50 over pistons right? Quote
