Hello again, Well now i have a job now and im working on my engine. I got them resurfaced. Now all i need to get the engine put togetther is (pistons, wrist pins, rings,and clip ring that hold them in) I have a new set of gaskets already, becouse i just got the them resurface can i get the same size piston that i had before or do i have to go bigger? Does n e 1 know if wiseco just the items i listed above if so i can be done with the engine. any help, comments. suggestions, or any thing would help.
If you only honed the cylinders out, you can re-use your old ones. You should always have the pistons you want on hand whenever you do any machining to your cylinders. Make shure the proper clearences are kept and you should be fine.
