FMF Fatty Pipes
FMF Power Core 2s
Cool Head w/21cc doms
Race Logic Porting
28mm Flat side Crabs
Vitos Power pistons
V-Force Delta 2s
Boost Boostle
Team Alba Clutch kit
Hinson Clutch Basket
Hinson Cushions
Hinson Pressure Plate
Vitos Trail Degree key
Lightened FlyWheel
Pro Flow intake
6 filtered air vents
There is alot more to it than just mods. It is more about, weight of rider, chassis set-up, tire size, track conditions, and then mods.
Those bits of information would be helpful, as well as what gear you launch in, and what gear you cross in- plus roughly where it is in the power range. You want it just about topped out in that gear (I use fifth).
Ok I am 270LBs and I still have the stock Chassis with With Work Ultacross rear Shock and Custom Axis Front shocks and Razr 2 rear Tires (20/11/9) with self tapping screws in them and Razr Front tires 21/7/10. And I start off in first or Second gear.
On some tracks it will lift and on some it wont Lift it is all according to what the track is made of. I want to cross in 5th.
No I do not want to run Struts right now Because I still Trail ride.
Have you ran the bike before? How does the 14/41 work for you?
Try to set the bike up to leave in second, first gear is kind of short and pointless, plus I would rather not have to shift thru neutral if at all possible.
