If they are keihns, I have a welded bowl that I can trade. The bolt at the bottom has been removed and is welded over. It's from a 35mm pwks but I think the pj's are the same bowl. I can verify if you wanted to trade.
Some people use reed spacers also.
According to www.carbparts.com the float bowl numbers are as follows
pj 34mm - W1350-289-9910
pwk 35mm- W1350-311-9910
So, I guess they are different. Sorry about that. You may take it to a welding shop and have it welded without the bolt in place.
Dude, bend it down. It's like less than half an inch. We do it to bikes that get the PJS and PWKs. It does not hurt a thing. everything still works great. Reed spacers will raise the carb some. I've never had a problem bending the clutch arm down.
