superchicken Posted August 15, 2004 Report Posted August 15, 2004 if your sure its your water pump,its a good time to buy a mega flow impeller.pull of the clutch cover and before you pull out the impeller try moving it around to see if the bearing has some play in it.if so get a new bearing and seal and your waterpump in now worry free.BTW got the nerfs the otherday what kind are those so i can get some new nets wile there out getting polished. Quote
harley_sr Posted August 15, 2004 Author Report Posted August 15, 2004 Man I have no idea on the nerf bars, they were on the banshee when I bought it. You might want to PM SickBanshee990 I got it from him, he should know. Also on the water pump, I bought a new Pro Design Impeller, and a New Water pump kit witch has a new bearing, seal, and gasket. Should that fix my prob.? Quote
FATBANSHEE Posted August 15, 2004 Report Posted August 15, 2004 that should fix the water pump ticking problem, just as long as the white plastic gear on on the inside Isn't worn or melted. that is the only other part left to replace. It may be ok just check it out also. ...FAT Quote
