Can somebody help me on which size of domes i need to buy with a coolhead? I just bought a 2004 limited edition banshee a few weeks ago with the K&N air filter, dyno jet kit, procircuit platinum racing pipes with silencers and want a coolhead. Also, will i have to re-jet the carbs after putting a coolhead on? Thank you for the help!
You dont have to re-jet with the cool head
Dome size will depend on what you want your compression to be at and what sort of gas you want to run.
Elevation will also come in to the compression factor.
PM "dlnoss" and he will give you all the info you need, will also hook you up with the HQ discount :)
Edited by XTShee
it depends on your elevation and what kind of porting you have done here are some specs
Sea level 1000' 2000' 3000' 4000' 5000'
15cc 217PSI 182PSI 176PSI 169PSI 163PSI 157PSI
16cc 211PSI 176PSI 170PSI 163PSI 157PSI 151PSI
17cc 205PSI 170PSI 163PSI 157PSI 151PSI 145PSI
18cc 193PSI 163PSI 157PSI 151PSI 145PSI 139PSI
19cc 181PSI 157PSI 151PSI 145PSI 139PSI 133PSI
20cc 169PSI 151PSI 145PSI 139PSI 133PSI 127PSI
21cc 157PSI 145PSI 139PSI 133PSI 127PSI 121PSI
22cc 145PSI 139PSI 133PSI 127PSI 121PSI 115PSI
Stock 130PSI 124PSI 118PSI 112PSI 106PSI 100PSI
THAT TOOK FOREVER!!!!!!!!! BUT THERE YOU GO
Edited by bansheeboy2004
You should be okay with 20cc as long as you don't advance the timing.
