Noob Banshee Posted August 9, 2004 Report Posted August 9, 2004 Hi i was wondering if i should replace my pistons or not im going to place a pic of it here and tell me if you think i should or just clean it out and run it if i dont right now ill be saving my self 250 bucks for right now. Quote
brock_fuzzy_69 Posted August 9, 2004 Report Posted August 9, 2004 depending on which bore your at you could possibly get a used set from somebody off this forum then jsut have the juggs bored and use the much less expensive pistons with new rings top end jobs on a banshee can allmost be done with your eyes closed its just a super simple machien to work on if you lived by me i woudl help you do it evan Quote
Noob Banshee Posted August 9, 2004 Author Report Posted August 9, 2004 this is a pic of my friend and his cousin YZF450 today, and the other is my pistons. what should i do about my pistons? Quote
frocashmoney24 Posted August 9, 2004 Report Posted August 9, 2004 damn ur pistons and jugs look rusty.. i'd hone the clyinders, and get some new pistons the same size, but before you do that, do a compression test Quote
itsaripper Posted August 9, 2004 Report Posted August 9, 2004 Do you have a air conpressor? Blow those cylenders out. You need the head on to get a compresson test. Was it hard to start? Or had no power? Why did you take the head off? Run those pistons up to the top and take your pocker knife and clean the carbon off and see if there is any numbers, like .020 or .030 etc. When you know what the bore is then you can have a machine shop mic the bores to see if they need to be bored. Quote
