421stroker Posted August 4, 2004 Report Posted August 4, 2004 What is the advantage of running two seperate brake lines with a banjo bolt vs. one that splits to two? Quote
Cotton eyed Joe Posted August 4, 2004 Report Posted August 4, 2004 What is the advantage of running two seperate brake lines with a banjo bolt vs. one that splits to two? NONE! I have the brake lines that use 2 banjo bolts, and it was a pain in the ass to get them lined up right so they didn't leak. As soon as I get the chance I'm switching over to an inline T. The price is about the same since the T's are about 2x as expensive as the banjos. You just don't use as much braided steel line. Quote
jinx44 Posted August 4, 2004 Report Posted August 4, 2004 Where can I have a custom braided line made up at? I need one to go from the front master to the rear caliper on a +10 swingarm. Quote
