96dragbanshee Posted August 3, 2004 Report Posted August 3, 2004 i have a 96 banshee it has some modifications and will run 82mph in 1/8 of a mile what can i do to speed this time up the mods are listed below t5 pipes 40 over with wiseco pistons cool head with 22cc head keihin carbs kn air filters shaved plastic barnett clutch itp holeshots Quote
ybanshee203 Posted August 3, 2004 Report Posted August 3, 2004 You could change your gearing if you don't mind purchasing a lot of different sprockets to see which setup works best with your modifications. Quote
96dragbanshee Posted August 4, 2004 Author Report Posted August 4, 2004 i am sorry i didnt list that i have a 15 tooth up front already with 2 13 tooth for trail are there any other mods Quote
Screamin_Banshee Posted August 4, 2004 Report Posted August 4, 2004 You'll get more replies in the drag section. A few suggestions. Timing, Reeds, Pipes (higher revs), little more compression. And maybe some more tuning- not to say it isnt right, but there might be some un tapped power in there somewhere. Quote
roosthrower Posted August 4, 2004 Report Posted August 4, 2004 out of curiousity, what's your et and 60ft times? Quote
