sweetshee4312 Posted August 1, 2004 Report Posted August 1, 2004 Well im rejettting the carbs, la la la, and i take a screw off and it falls on top the case, so im diggin around, i cant find it, i look, theres a hole there, on the top of the cases, like a machined one, the screw fell in it, is this bad Quote
Indubitably Posted August 1, 2004 Report Posted August 1, 2004 Did the screw go straight through? If so its just a hole for water and other stuff to drain through is it near the base of the cylinder? Quote
banshee04le Posted August 1, 2004 Report Posted August 1, 2004 Yeah dude if it fell in that hole, start looking on the ground because thats where it would end up unless you have a skid plate, then it would be on top of that. Quote
sweetshee4312 Posted August 1, 2004 Author Report Posted August 1, 2004 phew...thanks i will start lookin Quote
SICK BOY Posted August 1, 2004 Report Posted August 1, 2004 If it gets stuck in that hole,just spray water in it with a hose and it will knock it out. Quote
