looks like ya had a crank go bad and the piston hit the head u can send it to a performance shop and have it cut and rechambered and u will probably be able to get it right out and it will run fine but as for running it like it is now i wouldnt do it cuz the combustion chamber of that head is really messed up and the bike will never run at peak performance again until its fixed
Did you take your cylinders off and take a look at your pistons and down in your crankcase yet. I would reccomend doing that before putting that head back on. Then get an after market head instead of that stock one.
damn dude, you got something stuck inbetween your piston and head at one point, i do belive ur piston is fucked, unless this is from a previous piston explosion, check the piston on that side for damn sure, and a new head is in order, i dunno if milling it will take that out, ask boonman
