I'm breaking up around the low to mid range. It's fine when I pin the throttle, but just crusin its breakin up a bit. I have ptr mids, bored 20 thou, v-force reeds thats really all that effects jetting, oh k&n with lid on but no snorkle and cut inside. Stock pilot, needle 4th clip, and 310 main. What do y'all think. Plug looks ok on a mid range chop though, just not sure what the fix will be.
Breaking up, hmmm, sputtering, blubbering, sounds wet and throaty or like it's runnin out of gas?
I agree with loco, my experience (what little it may be) seems to lead me to believe that midrange pipes like a slightly fatter pilot. 27.5's will probably be your ticket. I'd try that and see how she does, and I'd think the 4th clip should work fine. My Fatties with stock carbs were 310s/4th clip/27.5 with same reeds and airbox mods.
Give it a try and get back.
I'll pick one up today and let you guys know when I get back from riding. I kinda had a feeling that would be the cure, just wasn't sure what to bump it up to. Thanx for yhe help.
