Where does the c clip or ring looking things go there are 2 of them one is before the big nut thing and other is floating on the end where the hub goes. I believe one is correct. the one on the nut.
yea it goes on the other side of the brake hub. towards the wheel. basically they go to the far outsides of everything. let us know how you like it, i hated my durablue. that lock nut POS never stayed tight and was a pain to get off with that stupid ass c clip deal. i got a lonestar now :D
So they both go on the oposite sides of the break hub?
ok looking from the back. the first one slides all the way down the axle and goes towards the right of the brake hub. then the other one goes on last. so when you assemble the axle it goes in this order.
1. c clip
2. brake hub
3. then insert axle into carrier
4. sprocket hub
5. lock nut
6. other c clip
then you tighten down the axle nut against the c clip
I heard a lot of bad things about the durablues, but I got a deal I couldn't refuse on a new one. I actually really like mine. I've bashed it in 3rd gear against some pretty hefty tree trunks, landed some nice doubles and triples and it's beat me around, but never once damaged that axle, yet I should say.
Mine is going on its second season and no problemos so far and havent had a single problem with the lock nut coming loose.
I have the X-33, and same here. Zero problems...
How you like the adjustability of it. Do you actually adjust it that much since your a dune'r and not an mx'r???? I'll trade you my LSR for it.........
I've never adjusted it once, when I installed it I set it to max width and left it. Why do you want to trade?
