This things never gonna run right... just rebuilt the whole thing and started it and an oil seal broke so i tore it apart and found a screw wedged in the gear in front of the clutch... took it out put a new oil seal in cleaned all the metal shavings out... started it, not its only firing on one cylinder , checked all the wiring and stuff it seems good, did plug tests and the left cylinder has a really weak spark , it sparks once every 5 kicks, then the right plug doesnt spark at all. What could be causing this?
I beleive the exact same thing happened on mine
Does yours fire more when your in a certain RPM range? My left cylinder would fire consistently, but the right one would only fire every once in awhile, but when i reved it, the right cylinder would start firing good for a few seconds, then as I passed the band it would go out, then farther up it would start sparking again
Something tells me CDI or Coil
that has coil written all over it. im having the same issue so does anyone know where to find one cheap, or does MSD make one? cause MSD is the shiznit
Make sure your plug caps are on good, unscrew them, clip the wires back just a bit & re-screw them back on & make sure they got a good connection. Check your coil for good ground too. Just something to try anyhoo. ;)
