Klotzban1 Posted July 19, 2004 Report Posted July 19, 2004 I pulled my shee out of the shed and let it warm a few up for a ride after installing better stock manifolds than what I had. My Banshee ran great till it got warmed up, then it would start cutting out. Shee does this as I wind her in 1st and in 2nd. I did have to tilt my carbs alittle to slide the manifolds in place. I looked at the manifolds and there is alittle weather cracking around the area above the intake bolts. This might be the problem, but could there be other things I need to check? Quote
sredish Posted July 19, 2004 Report Posted July 19, 2004 Have you done anything to warrant a rejet, and/or have you messed with the jetting recently? When it cut out, was it a sputter or boggy, or just quit for a moment then come back. Quote
ledofthezep Posted July 19, 2004 Report Posted July 19, 2004 When it cut out, was it a sputter or boggy, or just quit for a moment then come back. Good question. Quote
Klotzban1 Posted July 19, 2004 Author Report Posted July 19, 2004 (edited) It all seemed to start after I installed a better set of stock manifolds that I bought off a member. I made sure that there wasnt any foreign particles in the manifolds. As I installed the manifolds I had to tilt my carbs alittle to slide the manifolds in place. After installing the manifolds I hand tightened the manifold bolts. There was a few times I had to reach down between the carbs and hand tighten the inside bolts to the intake manifold. I tried not to touch the screws on the back of my diconnected tors unit for the fear of knocking the slides out of sync. I havent done any jet work since my pipes were installed a year ago and the Shee seemed fine before I installed the used manifolds. My Shee sounds like it Sputters more than Bogs . Its weird,...I can take off and it will pick up speed sputtering, but it wont die out when it Idles at a stop with the clutch pulled in or in nuetral. At first I though I might have got something from my tank sucked into my jets, but I always try to keep my tank cleaned out every so often. My tors is diconnected and I have a tors removal kit set back for later installation. If this turns out to be manifolds are cracked I guess I'll have to look around for another good set. I checked my rubber boots that attach the airbox to the carb and seen no cracks. After riding around for a little bit I examined my fuel line and seen a few bubbles in the lines. Is this normal? Edited July 19, 2004 by Klotzban1 Quote
