well im not sure if this is a blaster related question or jus a general all around atv question so here it goes...tha other day i was riding my blaster down tha st goin home from a day of riding...it was about 65-70 degrees out mayb not even that...wen all of a sudden it jus shut off an came to a stop on tha side of tha road...this happend on tues. an i still cant get it to start?...idk if its tha spark plug or what...please help
~tom
Does it have gas? New plug? Did it make any noise when it died?
I had a friend who was riding his blaster down his street, and it died. ended up being a torn up ring. do you have compression?
there is compression, an it does turn over wen i kick it...there is gas an tha gas is on....tha plug...im not sure i havnt gone out to but another one yet. I was in like 4 gear wen this happend an all it did was die an it rolled to a stop...no noises or anything
mine did the same thing and it had a hole in the piston but if you have compression then it cant be that. only 4 things contribute to this. fuel, air, compression and spark. one of them isn't coming through. gotta figure out which one then why...
def. tha 1st thing im gunna do is get a new spark plug...it could be sumthin that simple, who know....if u guys have any more ideas jus let me know
an thanks alot
