so they say it is beneficial to remove it and it causes problems, well i want to what is it, where is it. and what does it do for my stock banshee. any comments would be appreciated.
I am too lazy to type this all out myself so this is taken from bens FAQ,
Q#29:What is the TORS?
A#29:TORS is the Throttle OverRide System found on stock Banshees. It consists of the large boxy carb tops, a switch on the thumb throttle housing, a switch on the parking brake perch, and a control box mounted to the frame rail above the left cylinder. The function of the TORS is to limit engine RPM if the parking brake is engaged, or if the throttle is released and the carb slides don
Edited by XTShee
