BansheeBoy17 Posted July 6, 2004 Report Posted July 6, 2004 Ok I'm in the "build up " stage of a complete tear down... just installed a hotrods crank and put the clutch on and stuff... just was wondering a few things before i totally finish it. 1. For the cases...are the only things that go in there the crank, gears, and oil seals? then u can put the cases together? 2. For the clutch , theres the black rings.... a friend of mine told me that I can throw them away if i want to since they only reduce clutch noise. Is that true? Quote
frocashmoney24 Posted July 6, 2004 Report Posted July 6, 2004 yup crank gears and seals, you can throw the rings away, then are junk, no aftermarket clutches run them, ive heard stock doesent even need them, good luck! Quote
