how hard is it to sync the carbs, cause i thought it just involved getting the slides even but from what i hear it is much more involved than that, any help is greatly appreciated thanx
If they are stock, the carbs have a little window where you can see the slides. just get them so they both appear in the window at the exact time. It's pretty simple. You might have to adjust the idle so they are both set even then adjust the slides. You can also pull the filter off and peer down the airbox to the carbs and do it like that...that's how I sync mine...If you really got some time you can get a vacume guage and set it by that...but your going to need a place to plug it into...some aftermarket carbs have a nipple you can attach it to.
