HEY GUYS MAYBE YOU CAN HELP ME OUT I WAS RIDING YESTERDAY AND NOTICED SOME PLAY IN MY REAR END SO I JACKED HER UP AND SHOOK HER ASS AROUND A BIT I NOTICED SOME BIG TIME PLAY WHERE THE SWING ARM GOES INTO THE FRAME RIGHT WHERE THE CHAIN ROLLER IS
IS IT BUSHINGS I NEED TO REPLACE ? AND CAN I STILL RIDE OR WILL I HAVE PROBLEMS THANX GUYS FOR HELPING
Your bearings are most likely bad. DO NOT ride with te bearings like that. You have a much higher chance of tossing the chain and then you will have HUGE problems.
Take the swingarm off and look at the bearings and the sleeve that the bearings ride on. Let me know what you find and I can hook you up with the bearings if that's what you need.
[email protected]
