00BlueShee Posted June 27, 2004 Report Posted June 27, 2004 I got a Durablue eliminator axle, and Im trying to put the sproket hub on but it wont go past the first spline, does the sproket hub have to be pressed on ? and is it suppose to slide past the first spline easy? Quote
sredish Posted June 27, 2004 Report Posted June 27, 2004 should slide right on, sure it's the right hub? Quote
txblueshee Posted June 27, 2004 Report Posted June 27, 2004 I got a Durablue eliminator axle, and Im trying to put the sproket hub on but it wont go past the first spline, does the sproket hub have to be pressed on ? and is it suppose to slide past the first spline easy? Sredish is right... once you get the splines lined up it should slide right into place. Mike Quote
rebelbanshee2 Posted June 27, 2004 Report Posted June 27, 2004 first spline? I dont get what you mean by first spline. do you mean the splines for the wheel hub? it should slide right on from the left side to right side. if you are trying to put in on the wrong side i think maybe the brake hub splines are larger Quote
sredish Posted June 27, 2004 Report Posted June 27, 2004 (edited) if you are trying to put in on the wrong side i think maybe the brake hub splines are larger good thought. the axle must slide in from right to left. then your sprocket hub and lock-nut and all should slide on from the left. if you slid it in from left to right, then your backwards, and nothing will fit they way it's supposed to. here's a pic of my axle. the sprocket hub just slides right on very easy and the lock-nut then tightens it all down. Edited June 27, 2004 by sredish Quote
00BlueShee Posted June 29, 2004 Author Report Posted June 29, 2004 I got it to work now, I had every thing backwords. Thanks for that pic, I wasnt sure which way the posi lock went. Quote
