I appreciate the help from all of you. I have check all of the above and nothing seems to be working. I have done a top end rebuild with new reeds. Im getting tired of messing with this thing, so I think I will sit back and wait for my cdi unit to show up. Lets hope that this takes care of it since I plan on going for a ride this weekend. I will keep in touch. Thanks
Ok, to add something to my problem to maybe figure this thing out. I can get my shee running by primming it with carb cleaner in the plug holes. This thing really acts funny. It will bog at times and it will idle high at times. I think I have a intake air leak somewhere by spraying it with the cleaner and it really idles up. Could this be my complete problem or just part of it. I cannot see any obvious cracks in the intakes. Should I use any RTV sealant to the gaskets. Should I take off my reed spacers. My shee will sometimes only hit powerband. Other times it just boggs out. Im not so sure if it really is the cdi unit, which I haven't gotten yet. I can pull the plugs after running the bike for a little bit and they are perfectly brown. What else could be wrong, or could my whole problems be the intake leaks. The bike will absolutely not start without priming it.
