jaysea1 Posted June 21, 2004 Report Posted June 21, 2004 Just installed T-5's and jetted Runs great. The problem I'm having is fitting the stingers onto the head pipes. There seems to be too much play. A little exhaust leaks out on the left side where the joint is. I'm using the black rubber clamps off of the stockers. Do I taper the end of the stingers to tighten up that joint? If so ...best method? Also I bought these gently used, and was I suppose to get rubber brackets for the silencer/frame mount? The holes from silencer to frame don't line up when stinger is all the way seated on pipe, is that due to excessive play? Please anyone with answers. Quote
bansheefreak Posted June 21, 2004 Report Posted June 21, 2004 with toomeys you have to have a lil hanger back on the silincers to mount them up... if you forced the silencer way up there that would prolly be why you have a leak where the stinger goes on the head pipe...as for the leak if that don't help then get some new hose and get it tight should not leak if you get it tight enough... Quote
