adeezy9183 Posted June 19, 2004 Report Posted June 19, 2004 hey guys i have a problem with my shift shaft moving back and forth and i heard that you need to get the clutch off and look behind it at the shift star. is this true? i hope so because i got the clutch off i just need to take the basket and all off. i think i need a gear puller. is that for sure what i need to get it off? please tell me. thanks guys. i'll talk at you later. Quote
big_block_banshee Posted June 19, 2004 Report Posted June 19, 2004 your clutch basket should just slide right off as well. if it doesnt the bearing on that shaft is prolly f**ked. Quote
adeezy9183 Posted June 19, 2004 Author Report Posted June 19, 2004 no you misunderstood me. i got that big nut off of the clutch but i can't pull it off. people say that i need a gear puller. do i or not? help guys. thanks Quote
itsaripper Posted June 20, 2004 Report Posted June 20, 2004 You could use a gear puller but that is getting extream. You should be able to put two screw drivers behind and gently pry outwards. A heal bar works good too. Just don't pry to hard, everthing there is aluminum and will crack or break. With the clutch plates out the basket should spin free, it rides on a bushing. The clutch housing is what is stuck. It is setting just inside of the clutch basket. If you pull the basket they both should come off. There is a thrust washer between them. So that is the extra washer you have when you get the basket off. I have use a puller on the clutch basket, but I only turned the bolt with a wrench holding it at the box end so I didn't have too much leverage. If it don't come off ya don't want to keep turnen. Quote
adeezy9183 Posted June 20, 2004 Author Report Posted June 20, 2004 hey guys i got the clutch and basket off. the thing was off the shift star that shifts gears. the only problem is that the shift shaft will not stay in place. it keeps on moving back and forth. i was wondering is this was normal or not. pleez help guys because this is really starting to irratate me. thanks guys. i'll talk to you later. Quote
