I have an 89 Banshee that has T5 pipes, a jet kit and been bored over, since I got it it has not run on 2 cylinders. One cylinder runs fine and the other one just pops occasionally. I put a new stator on it, checked the cdi, and the coil. The TORS was removed when I got it. Any help?
Change the plug on the side thats not fireing.Make sure you gap it right and if you dont have an extra plug clean the electrode on the bottem of the plug with fine sand paper.I hope this fixed your problem :D
Edited by Banshee~
There is not much of a power-band, my brothers stock warrior will out run me. I think the carbs are syncronised, they both open and close at the same time. Would the tors being removed incorrectly do this?
if you take off the seat and look at the carbs theres a little screw on the top of each carbmake sure there pointing the wright direction and are screwed in the same amount.If you dont know how to do that take it to a shop they can do it in 30 mins or faster.I dont know alot about tors removal but i would say that isent the problem.
i had the same problem onw time wiehn i boought mine , the guy i bought it from said it had a hole in the piston. got to looking and one of the reeds were broke. put a new set in and she ran like a champ. u may want to check ur reeds if u havent allready.
and yes, the tors will cause this problem if it is not disconnected properly. is the little black box under the left side of the radiator unplugged ? (left being your sitting on the quad) and all the sensors on the throttle too ?
