akpopeye Posted May 28, 2004 Report Posted May 28, 2004 i got one dome on my shee head that is badly pitted, how do you put a new one in????, or should i just get it resurfaced???? Thanx guys, Cameron Quote
fixitrod Posted May 28, 2004 Report Posted May 28, 2004 A good machine shop can deck and reshape the domes for you. It's around 80 dollars though. For another $100 or so you could have a noss head and bump your compression a bit while your at it. If it happens again.. god forbid... you can buy a dome to replace the bad one. Andy at www.grandriverracing.com does heads. He can set it up right for you if you want to use the stock head. The aftermarket heads also seal better and are suppose to cool a little better. Quote
frocashmoney24 Posted May 28, 2004 Report Posted May 28, 2004 if u wanna drop 200, get a noss where if it happens again u buy a new dome, if its a stock head, get on ebay, and get one for like 12 shipped Quote
fixitrod Posted May 28, 2004 Report Posted May 28, 2004 The noss head also has a different design dome shape for a little better bottom end. Quote
