i have a 2001 banshee that i just modded with fmf fattys, boost bottle, cool head w/22cc domes v-force reed valves. i got an fmf jet kit and installed 270 mains and put it on the fourth clip i did a plug check and the tip right were it curved was black also not all the time but sometimes it doesn't like to idle. any suggestions.
also would you recommend a new clutch if so what brand.
You sound pretty close. Read BenBB's jetting FAQ to compare your plug with his recommendations. As far as your idle, try adjusting you air screw a little and see if that helps.
I run a EBC Dirt Racer clutch and some here have had good luck with Tusk's clutch.
