nickxc Posted May 20, 2004 Report Posted May 20, 2004 I dropped one of my slides straight down on the cement and bent one of my needles. I bent it back but it was still a bitch to get back into the carb will this be ok or should I get some new needles???? If I get new needles there is no sence and getting stock ones since they are like $20 each but what kind should I get... vitos, toomey, ??? Thanks!! Quote
Basicorpse Posted May 20, 2004 Report Posted May 20, 2004 I would definetly get new needles if I were you. You dont want them binding up in there. I have a set of toomey needles in my carbs and I am very happy with them. Quote
sredish Posted May 20, 2004 Report Posted May 20, 2004 I would definetly get new needles if I were you. without a doubt. most of them will be fine. just get a new one that's not bent. Quote
boonman Posted May 20, 2004 Report Posted May 20, 2004 I straightened a needle once. It didn't work worth a shit. Get a new one. And be careful.... Quote
Banshee Pilot Posted May 20, 2004 Report Posted May 20, 2004 I have Vito's in my Banshee. I'm happy with them, but I'm not sure they're any better than any other needle. -Craig Quote
frocashmoney24 Posted May 20, 2004 Report Posted May 20, 2004 def get new ones, go to the dealer to get a new one, make sure the 2 you have are the same size! Quote
Justintoxicated Posted May 21, 2004 Report Posted May 21, 2004 I straightened both my needles...I just bent them back and rolled them along the table to make sure they were true. I don't know why this wouldnet work.. Quote
nickxc Posted May 21, 2004 Author Report Posted May 21, 2004 is there any advantage to vitos or toomey needles over stock or should I just get stock needles???? Quote
Justintoxicated Posted May 21, 2004 Report Posted May 21, 2004 (edited) I would go for the toomy ones..>So you could not bend it back? If you can bend it back perfectly straight you should not have any problems...you can just work it around on a flat table... Why does everyone just say buy new needles? Hey are so expensive for what you get... I believe the toomy's and vitos have a different taper that will affect your mid-throttle jetting. Edited May 21, 2004 by Justintoxicated Quote
MILO Posted May 22, 2004 Report Posted May 22, 2004 one of mine was slightly bent, and i straightened it out and haven't had any problems with it since. that was almost 2 years ago. but i've also heard that other brands need set up differently due to different lengths and thicknesses. Quote
