My buddy has a banshee with pro circuit pipes and 34 mm carbs kehien(sp?) he says at idle its fine but as soon as you touch the throttle one side lets out a big puff of smoke and looks like a forest fire?? The motor is fresh nothing burnt up or anything anyone have any input on this??? THanks guys
well, that's not exactly how I meant that to be interpreted. my bad for not being thorough.
However, it's not totally uncommon that one cylinder will get a slightly different air/fuel mixture due to the choke circuit and how it's setup on dual carbs. i would make sure the carbs are clean and no clogged jets. I would also suggest running a wide-open-throttle plug test to make sure your main jets are jetted correctly and that your plugs look like they're burning the same. Also, be sure to try new fuel and new plugs, old fuel can burn crappy and old plugs can keep from burning a complete combustion.
After you've ruled that both cylinders are running the same and there are no air leaks, carb problems, etc, and you're just having a smoking issue, it would probably be alright to adjust the pilot in one carb slightly different the other but I wouldn't adjust more than one size different than the other. If it requires more than one size to clear the smoke, you may have some other issues. Also, don't run your needles in different clip positions; always keep your needles and mains exactly the same.
Above all, make sure you have no other problems or issues before, so you don't mask another problem.
Later.
Edited by sredish
Check to see if the air screws are adjusted evenly (same # of turns out on each carb) and that the carb slides are synchronized. Does the big puff of smoke happen only near startup or all the time?
I'm not sure on when it happens sounds like it may just be low end power it is not mine so i dont know exactly he is going to pull both off make sure everything is equal and to the correct specification and clean them up see if it does anything run the shat out of it try and clean it up a little bit.Thanks for the info guys!
Mine did the same exact thing right after rebuild. One side smoked alot more than the other. My builder said to just let it run a little bit and ride it some and it should even itself out. After about 1/2 hour of riding everything was fine. Just make sure that its not leaning out too much and/or if it pops alot you may have jetting problem.
