BenBB Posted May 14, 2004 Report Posted May 14, 2004 Can a CDI get fried from soldering wires on the harness without uplugging the CDI ?? Probably not, since it's just heat. I always unplug my CDI when I'm welding on the frame, just in case. You check the stator yet? At the 4-wire plug you should have: Charging coil should be 13.7-20.5 Ohms (red to green wire) Pick up coil should be 94-140 Ohms (white/red to white/green wire) I've had both go out on my '96, but haven't had any probs with the coil, other than one of the connectors getting loose but nothing a pair of pliers couldn't fix. Quote
