Guest jmpnjckflsh
:wacko: i have a 91 stock banshee...i have read over and over on here about the things sucken...lol...well if it is the case then mine are doing just that sucken...there are wires that connect them to the carbs ...i disconected them now my question is this is there anything else i need to do...i cant afford to buy the tors removel kit yet...soon but not yet...help is greatly needed...im in need of speed and going loony without it.... :whoa:
Little black box above the left exhaust w/ a 3-wire plug, disconnect that and the parking brake switch.....The tors removal kit is just carb tops,,,doesn't really have anything to do w/ the tors to tell you the truth.....
unplug the wire coming out of the parking brake, then follow it down the left side of the radiator and unplug it down there also. They both need to be disconnected, for that to be totally out of there.
As long as you have the triangle plug disconnected from under the left side of the tank, you should be good to go.
