Hey all need a favor can you tell me or look at your banshee and tell me where the oil breather line and the water pump breather line rout to there is a tee connector under the tank does another line just route of that and act as a drain ?????? thanks
The tranny vent lines will run up under your tank and down around the back of the radiator..the radiator lines will run under the tank, back to the res. then back under the tank and behind the rad. as well...shit load of ugly tubing running under there. I suggest getting rid of it.
