8HONDO Posted May 3, 2004 Report Share Posted May 3, 2004 i ordered a tusk kit from rocky mountain which comes with 6 heavy duty springs.they just called me and said it will be another 2 weeks before i get it because of back order. they also mentioned that they have the exact same kit in stock but minus the heavy duty springs. my problem here is that i was only using 3 of the hd springs and 3 stock ones for ease of pulling. can i use 3 springs from a dirt digger clutch kit in place of the 3 that i was getting with the tuck kit? Quote Link to comment Share on other sites More sharing options...
randelator Posted May 3, 2004 Report Share Posted May 3, 2004 HI, FOR YOUR QUESTION THE ANSWER IS YES YOU CAN USE BARNETT SPRING ALL OF THE AFTER MARKET USE ALMOST THE SAME SPRING SO GO NUTS AND HAVE FIN Quote Link to comment Share on other sites More sharing options...
randelator Posted May 3, 2004 Report Share Posted May 3, 2004 HI, FOR YOUR QUESTION THE ANSWER IS YES YOU CAN USE BARNETT SPRING ALL OF THE AFTER MARKET USE ALMOST THE SAME SPRING SO GO NUTS AND HAVE FUN Quote Link to comment Share on other sites More sharing options...
8HONDO Posted May 3, 2004 Author Report Share Posted May 3, 2004 thanks Quote Link to comment Share on other sites More sharing options...
8HONDO Posted May 3, 2004 Author Report Share Posted May 3, 2004 also where can i order different springs from Quote Link to comment Share on other sites More sharing options...
Basicorpse Posted May 14, 2004 Report Share Posted May 14, 2004 Toomey has clutch springs on thier site. The springs are 100% stiffer than stock though so you may want to use half stock springs and half thier springs. Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted May 14, 2004 Report Share Posted May 14, 2004 run 6 stiff springs any kind you have will work Quote Link to comment Share on other sites More sharing options...
