H300F Posted April 29, 2004 Report Posted April 29, 2004 I need the distance from the front bolt mounting the lowwer aarm to frame to the bolt holding the shock to the lowwer aarm. what i want to know is if on +2+1 aarms they move the shock mount compared to where it would be on stock arms. Quote
ledofthezep Posted April 29, 2004 Report Posted April 29, 2004 The shock will mount in the same place unless you're running a long-travel setup. Aftermarket shocks are just as long as stock, just valved & setup different, 19" long-travel shocks will mount a bit different though. So you should be able to measure the distance on your stock arms. Quote
