Sheeboy12 Posted April 29, 2004 Report Posted April 29, 2004 People keep on telling me that i welded the ball on to a rod, never really thought about this b/c the ball looks like it's supose to stuck on the end. IS IT? Quote
frocashmoney24 Posted April 29, 2004 Report Posted April 29, 2004 nope there supposed to be sperate pieces, theres ur clutch problem Quote
JTQuad Posted April 29, 2004 Report Posted April 29, 2004 They are supposed to be apart. This is a very common Banshee Problem. - JT Quote
boonman Posted April 29, 2004 Report Posted April 29, 2004 That ball acts as the bearing between the clutch pressure plae and the rod that is moved by the engagement lever. I hope that you got the rod out with ease. Often times it is lodged inside the transmission shaft and is fairly difficult to remove. Keep your transmission oil level up to full, and don't coast ANYWHERE with the clutch pulled in. if memory serves me correctly, you stated in another post you were drag racing and at the end of the race, you had no clutch. I am guesstimating that you pulled in the clutch at the end of the run, and coasted a little. That will do it. Especially if the oil was a little low. Or, pulling in the clutch for every shift with the oil low, and draggin, (high RPM shifts) was just too much for it. Quote
ledofthezep Posted April 29, 2004 Report Posted April 29, 2004 So do you just replace the rod & ball? If there welded together do you have to crack the cases or what?...just curious because I think I may be in the same predicament. Quote
boonman Posted April 29, 2004 Report Posted April 29, 2004 Well, that depends if the rod and ball are stuck in the shaft. if they are stuck, splitting the cases is almost eminent. If it slides out, than you are in business!!!! If not, pull the motor and split the case, and press the ball and rod out of the tranny shaft...... Quote
ledofthezep Posted April 29, 2004 Report Posted April 29, 2004 Thanks boonman! Anyone happen to have the part numbers on the ball & rod? Quote
brock_fuzzy_69 Posted April 29, 2004 Report Posted April 29, 2004 i noticed that packard racing they sell a special machined thrust bearing that i beielve takes the place of the ball its like 40 or 50 bucks but it looked like a good setup pretty sure it was packard enterprices the company that does alky drag banshees mostly Quote
ledofthezep Posted April 29, 2004 Report Posted April 29, 2004 Interesting Brock...anyone else got any info on that deal? Quote
boonman Posted April 29, 2004 Report Posted April 29, 2004 it is basically a thrust bearing. With a small machined "tit" that goes in place of the ball. It almost can't sieze up. Unless you had no oil in the tranny.... You can find them on Ebay as well..... Quote
ledofthezep Posted April 29, 2004 Report Posted April 29, 2004 So is the thrust bearing setup the way to go, what's the pro's/con's vs. stock ball & rod?...other than it not being able to get fubar'd? Sorry for all the questions...just curious. Quote
frocashmoney24 Posted April 29, 2004 Report Posted April 29, 2004 i got my new one at www.vitosperformance.com get the whole rod ball n screw for like 12 bucks, u cant beat that shit! Quote
350duner Posted April 29, 2004 Report Posted April 29, 2004 If you are going to replace it there's no reason not to go with the new thrust bearing style setup. It's cheap and much more durable. My cousin went to one after welding his ball to his rod *snicker* about 5 times. When I go to my lockup i'm gonna switch to that style also. Cheap insurance. Quote
ledofthezep Posted April 29, 2004 Report Posted April 29, 2004 If you are going to replace it there's no reason not to go with the new thrust bearing style setup. It's cheap and much more durable. My cousin went to one after welding his ball to his rod *snicker* about 5 times. When I go to my lockup i'm gonna switch to that style also. Cheap insurance. Where to order? Part #? Price? Quote
Meat Posted April 30, 2004 Report Posted April 30, 2004 led just contact Vitos' or GRR or just about any Banshee performance shop and they'll have the pancake bearing setup mentioned. Quote
