You can probably see my mods below... Which ones should I run. With the 19cc I get usually around 140 psi and the 17's I get about 175. (remember it's ported by Patriot). Which ones do you think would give the most power (mostly for drag racing). I only run 110 octane so fuel is not a concern.
Thanks
since ur running that octane already, and i see that ur crank is already welded, go for the 17's
Agreed. You'd be wasting that 110 anyway with 19cc domes. Go with the 17cc, your plenty set up for it and will be happier.
