QuadMX Posted April 29, 2004 Report Posted April 29, 2004 When I take my clutch case off, can I cut a hole behind the clutch case insert so I can adjust the clutch without taking the entire case off? Theres the rubber o-ring type thing behind the stock clutch insert. Would that be enough to hold the oil with a hole in the actual case? Bob Quote
BdBanshee Posted April 29, 2004 Report Posted April 29, 2004 You mean like this? Works great and doesn't leak either. Mine has been this way for over 14 years. Quote
QuadMX Posted April 29, 2004 Author Report Posted April 29, 2004 YES! Just like that...What'd you cut it with? Quote
BdBanshee Posted April 29, 2004 Report Posted April 29, 2004 I bored it using a Bridgeport mill and a offset boring head. But I have done several since with a 2 1/2" hole saw. Works just as good and a lot less work. Quote
00BANSHEE Posted April 29, 2004 Report Posted April 29, 2004 Mine is the same way. Only I used a 1 inch hole and have a rubber plug that fits perfect. Then I put my polish cover back on. Never leaks a bit. All it takes is a deep socket and phillips screwdriver and about 5 mins to adjust my clutch. No need to drain the tranny fluid as it is below the hole. Quote
350duner Posted April 29, 2004 Report Posted April 29, 2004 Sweet, I'm gonna try that. Since my bridgeport mill with the offset boring head is on the fritz I'll try the holesaw method. ...And if it leaks it'll be a great excuse to do that lockup clutch cover I've been drooling over! Quote
