damn i got excited , i saw fro... check out naxbanshee, he' just set his all up, its a couple posts down in this forum, im sure he'll help u get on the right track
Well man u wanna stay real narrow I went with +1+1 quicksand a-arms and a -1 swing arm both highly recommanded. also u need a bigger tank and a 2into1 carb setup is a must I also went with a 2into1 pipe but thats your choice. U want to have a machine that u can trust to ride full throttle for 2 hrs or more in mud and water. so motor work is not really that big a deal but u want alot of low end so the 2into1 carb and pipe takes care of that and a port job might not be a bad idea with a coolhead o yea a steering satblizer is a must. If u got any questions just let me know. We need to keep the banshees in races like thses
Lots of compression!!! Banshees need lots of compression to pull down low. I personally run 215lbs of compression on my ported 99 XC shee. Next thing and just as important in not more is suspension. A good set of shocks will make a difference in night and day. Mike
  • 3 weeks later...
You definitely gotta work the front end, you're gonna need to have a sick handling quad if you have to run with some of those 4 strokes
